Home Forum Ask A Member Merc Mark 5 neutral cable
  • #254049
    Boonie
      This doesn’t go into neutral. First time seeing this set up. Cable moves slightly but stayes in gear. This is how I received it.
      #254051
        looks like it is similar to TN neutral cables… have you tried resettitng  it  by loosening the clamp .   see if it operates by pulling it manually with  pliers
        #254058
          ALL the slack out of the cable.
          • This reply was modified 4 years, 1 month ago by DAVID.
          #254071
            Be careful not to fray the end of that cable. If you do, changing the impeller will be harder to do than it already is.
            • This reply was modified 4 years, 1 month ago by billw.
            #254073
            Boonie
              Oh now your scaring me! Is this a complicated motor to work on? What does that cable have to do with the impeller?
              #254080
                likely nothing but fishing a frayed cable back up  to the clamp  won’t be fun
                #254086
                  When you drop the lower end to change the impeller, that cable necessarily gets pulled out of its tube. On assembly, it has to go back up the tube. When the cable end gets frayed, getting it back up the tube is really hard. Your cable looks pretty darn good right now. I am just advising you to be respectful of it, that’s all. The impeller change is harder than you think but easier than you probably fear. Probably. It just takes an extra dose of patience, like all Mercs. Mark 5s are really, really good runners when they’re right. They will run circles around a comparable Johnson TN28, with half the smoke.
                  #254118
                  Boonie
                    Did some messing with the cable slack. I have neutral now. Thanks. I’m assuming corn head grease is the choice for the gear case? There’s only one fill screw no vent.
                    can these be fixed-welded?
                    #254138
                      Yes there is a vent. look up higher.
                      Yes corn head grease.
                      Yes they can be welded. I get a piece from another junk motor and fit it first. then weld.
