Ok Guys, I’m working on replacing the crankshaft seals on my Mk 28 power head and just received the seals for it ! In looking at the two lower seals they are identical except the one has a tiny home drilled thru the steel case. So my question is which one goes in the lower position facing the lower unit and which one faces the crankshaft ?
My instinct tells me the one with the hole goes in facing the lower unit and the other one faces the crankshaft !
My other question is, why ? Hope someone has the answer ?
Thanks
Gary
This topic was modified 3 years, 12 months ago by
geary.
