Home › Forum › Ask A Member › merc o tronic 98
- This topic has 15 replies, 8 voices, and was last updated 4 years, 12 months ago by
Ken Smith.
March 15, 2021 at 6:13 pm #233951
how do you troubleshoot a merc o tronic 98? nothing looks burned or shorted….if i plug it in it does nothing! Is the light supposed to light? does it need the battery to work properly! Its getting voltage to the inside where it connects to the unit! Is there a transformer inside? please help
March 15, 2021 at 7:04 pm #2339527 1/2 volt battery is needed to work all but the condenser checks. 1 914 310 7086.
I get a 7.2 volt battery for remote toys with charger. get as large of one as possible.March 15, 2021 at 8:01 pm #233962I found a manual online,
March 15, 2021 at 9:14 pm #233967The first two items to check are the vibrator and the 10 ohm potentiometer. Over the years the contacts in the vibrator can become dirty or corroded. The unit can be carefully disassembled and cleaned. The potentiometer is also a point of failure due to dirty or burned contacts or wiper. Schematics for these units are difficult to find. Here is a link to a discussion of the 9800 on the Smokestack forum that you may find useful. https://www.smokstak.com/forum/threads/merc-o-tronic-9800.125077/
March 16, 2021 at 7:56 am #233988you could probably hook in a 7.2v external source by using a power supply with a connector or plug interface . or stuff it inside space permitting
respect polarity , current needs and voltage rating.
if volts are a bit high you can wire in a couple of diodes to drop it (check diode specs for voltage drops& amps rating x diodes needed.)
For silicon diodes, the typical drop is 0.7 volts
March 16, 2021 at 9:51 am #233994The usual problem is the vibrator. The contacts become dirty of pitted. It can be carefully disassembled and cleaned. The other thing to check is the large 10 ohm potentiometer. They also have a tendency to get dirty and lose contact. Schematics for the Merc-o-Tronics are difficult to come by. The is an older discussion on the Smokestack antique engine forum you may find useful.
This reply was modified 5 years ago by
mic57.
March 16, 2021 at 11:05 am #233998March 16, 2021 at 2:47 pm #234008Where are the points located?
March 16, 2021 at 7:12 pm #234026open the top. (2 screws). it is on the right side front in the sealed container. call me 1 914 310 7086 Dave.
March 17, 2021 at 5:59 am #2340421.You REALLY need the instruction booklet.
Also NOTE…plugging it in does NOT work for testing coils….Unless you have converted it to run from a power supply.
Refer to statement #1
Regards
Richard
classicomctools@gmail.com -
