Home Forum Ask A Member merc o tronic 98
  • #234053
      There is a manual available to view or download in the Members Only section here. It’s in the Old Iron Reference library.
      #234070
      EDWARD A. KOSTIK
        I have the instruction book…it dosent tell anything about troubleshooting
        #234071
        EDWARD A. KOSTIK
          when I hook up a 7.5 volt battery to the unit and turn it on it makes a buzzing sound and the light lights but thats all
          #234072
            Like I said give me a call. 1 914 310 7086
            #234103
            RICHARD A. WHITE
              You say it makes a buzzing sound? Then you should follow the instructions and connect a coil per the instructions. You, once it is all connected properly, will need to rotate the dial, which increases voltage to the coil, at the point, IF the coil works, you will see spark thru the little window, when the spark is consistent and rapid, read, the scale to determine the input voltage and then compare that to the specs in the book.
              classicomctools@gmail.com
              #234127
              Ken Smith
                You should really call Dave Bernard. He can help you with anything Merco-tronic.
                www.kenadianoutboards.com
