TRICKY QUESTION..,20631 used EXCEPT when using flywheel 206-750 and magneto 320-746 Bendix K2A-5 So you can use KE7 Starter, Ratchet Nut on KF7, KG7 or KG4, except for above flywheel magneto combination. Per the parts manual.
KE7 uses impeller 24472 KF7,KG7,,KG4 use 47-21164
Not sure which impeller chart you want, There have been several articles in Antique Outboarder regarding adapting impellers with some cort of chart included,
Good Luck
This reply was modified 3 years, 1 month ago by
green-thumbs.
