Home › Forum › Ask A Member › Mercdry KG4 carb settings
What are the initial carb settings for a KG4?
Thanks, Jim
The 1965 and prior service manual mentions low speed one turn out and high speed 1 1/2 out
What I found confusing at first is the fact that the needle controls air,and not fuel. Turn clockwise to rich up the mix
Thanks, Wedgie…..That’s good to know
Jim
If the idle needle is in the front rich is counter clock wise for rich. If it is on the side it is clock wise for rich. you can take that to the bank.
OK
