Home Forum Ask A Member Mercury 110 ?
  • #233416
    bunky
      I have by the serial number a 1966 (1983615)
      Mercury 110, when I bought it the tiller handle was broke.
      So this winter I decided to tear it down and replace the bracket I’m now getting it back together and ran into an issue the gasket I ordered 27-89937 doesn’t fit right along the right rear of the engine the gasket only covers about an 1/8″ in spots did mercury change this gasket ? Or do I have the wrong part number
      Also the kill switch works but the wires are rough shape I don’t see a replacement so do I just solder new wires onto this switch?
      #233508
        Both the Marine Engine site and Mercury’s dealer site say that gasket is the right one for your engine. I don’t know what is going on. Could it be the serial between the bracket and power head have been mis-matched over the years?
        I don’t know exactly how Mercury built those stop switches, so my idea to repair the wires may not work….But…..I recently worked on an OMC 18 hp with the same problem: bad wires to the stop switch. I found that the wires were crimped into the switch contacts. I was able to carefully press out the contacts, cut the wire off the contacts, then carefully drill the remaining strands out of the contacts. I cut some new wire, inserted it into the contacts, re-crimped them, and fed the wire and contacts back into the switch. You can’t tell it from OEM, now and it works good. Hope that helps YOU….
        #233537
        outbdnut2
          I have had success placing shrink-tube over bad wire insulation in those old Mercs – shrink it with a hair dryer. It looks good when you are done too! …or solder new wire to the old wires an inch or so behind the switch (or use inline crimp connectors) and put shrink over the solder joint or crimp connectors when done. You can get shrink tube at good hardware store or Menards. Note some years of Mercury stop switches are just normally open , momentary shorting switches, but some years there were electronic parts embedded in the switch – like maybe a diode or two. An ohmmeter check will tell you what you have. I learned that when I went to swap a switch from a newer model to an older one.
          #233540
          bunky
            I thought about the shrink tube as well might just go that way. Yes I believe this switch is closed until you push it then it breaks the circuit if I remember correctly.
            #234815
            bunky
              So I got to looking at my switch and it came apart. So I disassembled it and found that the wires were just soldered on the end of the prongs so I was able to unsolder the old wires and resolder in some new.
              #234928
              seakaye12
                Generic push button switches like this one work fine for Mercury replacements where the ignition is not normally grounded. Pushing the button grounds the points and kills the engine.
                They are sold everywhere it seems….
                https://www.amazon.com/s?k=0779172186767
                • This reply was modified 4 years, 11 months ago by seakaye12.
                #234930
                  heat shrink tubing source….. try flea markets …. I buy the stuff in $1 bags for a mix of size and color 10-12 inches long works perfectly
                  you get about 20-24 tubes of heat shrink per bag
                  • This reply was modified 4 years, 11 months ago by JACQUES.
