Home › Forum › Ask A Member › Mercury 20H Rod Information
Does anyone know the dimensions of the Mercury 20H connecting rod? Specifically the crank end bore diameter and the wrist pin end bore diameter. I am assuming that the length is the same as the KG7 rods. Any help is appreciated.
20H Connecting Rod Piston Pin End .750 Crank Pin End 1.137
Travis
Thank you!
OK
