Home › Forum › Ask A Member › Mercury 9.8 Reverse lock out?
- This topic has 12 replies, 3 voices, and was last updated 4 months ago by
JACQUES.
October 21, 2025 at 7:37 am #300810
I have a 70’s Mercury 9.8h.p outboard.  The reverse lock lever is busted, I have read where some guys say to leave it off.  I would like to fix it. This motor has has the lever that goes side to side not up and down..
Do I leave it off or fix it ?
My problem with leaving it off is the motor locks down and I cannot lift it up when loading onto the trailer..
October 21, 2025 at 10:17 am #300811better fix it ..if you hit something on the water severe damage will cost $$$
the alternative is it disable the hooks  but the leg will lift up is high reverse
POST MODEL #Â Â serial #
Joining AOMCI has priviledges đ
October 21, 2025 at 12:11 pm #300818There are a lot of 9.8 and similar 7.5 HP motors around (at least in Minnesota where I live). If you need parts, look for a cheap “Parts motor” that has what you need. Other parts may come in handy later!
Dave1 user thanked author for this post.
October 21, 2025 at 5:42 pm #300830most of those have a small flip up- down lever ?  pulling up a spring on the lock hooks ..
October 21, 2025 at 8:18 pm #300836better fix it ..if you hit something on the water severe damage will cost $$$
I’m not sure on the year and serial number the tag on the clamp is missing..  the motor has a blue band on the cover and says 110.
Is there another location for the serial number?
October 21, 2025 at 8:19 pm #300837most of those have a small flip up- down lever ?  pulling up a spring on the lock hooks ..
My older 9.8 has the lever you press down to lift the motor.
This one goes sideways and I’m not sure I have all the pieces.
October 21, 2025 at 8:38 pm #300841sorry all I find on 110 version is the regular small tab  lock release. wait for our Merc expert comments
October 21, 2025 at 10:33 pm #300842all I find on 110 version is the regular small tab lock release.
I seem to remember that the 9.8 and 7.5 had a redesign some time in the late 1960s or 1970; and a lot of stuff changed, like I know the the carb was totally different, and ignition was improved. I never paid attention to the reverse lock to see if that changed, and my parts motor examples of each are too far buried in storage for winter for me to take a look to see if that mechanism changed also.
October 22, 2025 at 7:50 am #300846Mercury Marine 110 Clamp & Swivel Bracket Assembly Parts  see part #27
 I tried to post my search on AI but it POOFED twiced…. đ
October 22, 2025 at 9:40 am #300844see picture in this link found after CHAT GPT search
<article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”4954af4f-d114-4625-8ce5-7f99df1b387a” data-testid=”conversation-turn-1″ data-scroll-anchor=”false” data-turn=”user”>
 Q: what year were Mercury 110 outboards with the blue band on the cowl made ?</article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”bc81f9a2-f20c-4730-9bb2-6dd71c610042″ data-testid=”conversation-turn-2″ data-scroll-anchor=”false” data-turn=”assistant”>
ChatGPTsaid
If the Mercury Model 110 (9.8 hp) outboard youâre referring to has a blue band around the cowl, it most likely dates from approximately 1973 to 1977. Boating Forum – iboats Boating Forums+1
Hereâs a summary of the evidence:
One forum post states: â~1969 to ~1972 Red band ⊠~1973 to ~1977 Blue bandâ for Mercury cowling colours. Boating Forum – iboats Boating Forums
Another thread on decal styles: for years â72-â76 the classic tilted-letter logo had âblue and chromeâ. screamandfly.com
A comment from one user: âblue is 72 and up areaâ when discussing a Mercury 110 with a blue band. aomci.org
Caveats
These colour-band indications are approximate; Mercury used serial numbers for exact production year modelling rather than relying solely on cowling colours. maxrules.com+1
The blue band does not guarantee the exact year, so checking the serial number stamp on the engine block (usually between transfer port covers) is the best path for exact year identification. JustAnswer+1
If you like, I can check a serial-number chart for the Model 110 and narrow it down further for your exact engineâwould you like me to dig that out?
</article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”67b22e02-2e9b-47f5-88f6-f4acdf7ffd2e” data-testid=”conversation-turn-3″ data-scroll-anchor=”false” data-turn=”user”>
Vous avez dit :
which on hada tilt lock release lever operated from side to side versus the one’S with the small tab which works up or down to lock-releases the engine</article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”38b96610-1e84-4ff7-9c6b-a4f3f3cf9244″ data-testid=”conversation-turn-4″ data-scroll-anchor=”false” data-turn=”assistant”>
ChatGPT said
<button class=”flex w-full items-center gap-0.5″>RĂ©flexion durant 15s</button>Short answer: the mid-1970s (the blue-band 9.8/110 era) used the side-to-side manual tilt-lock lever, while later models (late-1970s â 1980s and onward) increasingly used the small up/down tab style on the clamp/swivel bracket.
Why: parts diagrams and old parts listings for the 7.5/9.8/110 family from the 1970s show the conventional sideways tilt-lever assembly; later service/parts chatter and replacement-part listings show the smaller up/down latch becoming common on newer clamp brackets. crowleymarine.com+1
If you want an exact confirmation for your engine (so you can match parts or restore it), give me the serial number from the engine block and Iâll look up the exact parts diagram and year for that serial range.
</article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto scroll-mt-(–header-height)” dir=”auto” tabindex=”-1″ data-turn-id=”504a90a9-4711-435d-a0fd-caf01fcbc814″ data-testid=”conversation-turn-5″ data-scroll-anchor=”false” data-turn=”user”>
Vous avez dit :
serial number is not available but can you indicate the serial number series that have the side to side lock release</article><article class=”text-token-text-primary w-full focus:outline-none [–shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(–shadow-height) has-data-writing-block:pt-(–shadow-height) [&:has([data-writing-block])>*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] scroll-mt-[calc(var(–header-height)+min(200px,max(70px,20svh)))]” dir=”auto” tabindex=”-1″ data-turn-id=”7cbcaaf1-1571-41a0-af89-912136c56598″ data-testid=”conversation-turn-6″ data-scroll-anchor=”true” data-turn=”assistant”>
ChatGPT a dit :
<button class=”flex w-full items-center gap-0.5″>RĂ©flexion durant 13s</button>Good â since you donât have the tag, the best practical way is to use serial-number ranges tied to the mid-1970s âblue-bandâ 9.8 / 110 family (the era that used the side-to-side manual tilt-lock lever).
Serial-number ranges that correspond to the blue-band / mid-1970s 110 / 9.8 era
1972 (approx.) â starting around 3,263,263 â 3,482,752 (1972 production). southcentraloutboards.com
1973 â roughly 3,482,753 â 3,795,657. southcentraloutboards.com
1974â1976 (mid-1970s) â roughly 3,795,658 â 4,691,221 (documents list the 110/11.0 series in this block for 1974â76). mibo.cc+1
How to use this
If the serial number on the swivel bracket (or cast into the housing) falls inside those ranges, itâs very likely to be a mid-1970s blue-band 110/9.8 and therefore fitted with the side-to-side tilt-lock lever. If itâs below ~3.26M youâre into earlier 1960s models; above ~4.7M youâre getting into the later 1970s/early-1980s changes when the small up/down latch becomes more common.
</article>
