Home Forum Ask A Member Mercury 9.9 Mod
  • #299836
    geary
      I have a friend that has a 9.9 Mercury ( Don’t know the year). He wanted to know if it can be changed to a 15hp by changing the carburetor ? I know it can be done on a Johnson or Evinrude 9.9hp just not sure if it can be done on  Mercury ? Any suggestions or help would be appreciated. Thanks
      #299837
      RICHARD A. WHITE
        You could try to look up the parts list of the 2 motors and compare parts…
        classicomctools@gmail.com
        #299847
        Michael Anfossi
          International Member
          Yes it can be done, have done it several times
          #299861
          Gary Kosiba
            Hello group, I recently picked up a 9.9 Merc and would like to try this Hp modification.  Would it be just a carb swap or is there any modification to the intake or exhaust as well?  Thanks
            #299865
            seakaye12
              It would be a whole lot better if we knew the model of the motor you are working with.  2-Stroke?  4-Stroke?
              9.9 points to a newer Mercury series;  the ones they sold through the 60’s 70’s and 80’s was technically a 9.8.
              With Mercury it is always best to work with the serial number.
              #299889
              Gary Kosiba
                I have the info now.  It is a 110 and the serial number is 4840180.  Thanks in advance for your help.
                Gary
                #299892
                seakaye12
                  OK Gary,  your serial number shows a 1978 model which was the long running 10.9 cubic inch block which began in 1962 and went into the 80’s.
                  Mercury did not offer a 15HP version;  they went from the 10.9ci  9.8HP to a 21.9 cubic inch 20HP block.
                  At a paltry 10.9ci….I doubt that much more performance can be squeazed out of your 9.8.  It is already a tuned version of the 7.5HP motors.
                  #299915
                  Gary Kosiba
                    Thank you seakaye12 for the info.  I appreciate you taking the time.  Gary
                    #300037
                    outbdnut2
                      Note that the 9.9 replaced that 9.8 in 1986.
