Home Forum Ask A Member Mercury K?7, Wizard, Merc 200 hodgepodge…
  • #256502
    trex014
      I’ve got the bug to make the quickest “stock” 10hp* mercury wizard from the green tank era. The plan is to slap a Merc 200 powerhead on a K?7 (likely KE7) tower and gear case and hide it all under Wizard powermatic covers and 10hp decals.
      So far I’ve located a powerhead w/igniton and tower/ gear case. I’m thinking a Wizard Powermatic 12 fuel pump motor will have the most suitable cowling to use.
      Anyone have any tips or tricks to add to my project?
      #256503
        You will have to have little clearance at the carb. the KE7 tower with the KG7 lower will end up with more driveshaft engagement .
        1 914 310 7086.
