Home Forum Ask A Member Mercury KE4 Water Tube
  • #2277
    jpatti75
      I’m about to reinstall the powerhead onto the tower on my KE4. I noticed that the water tube where it emerges from tower is flared at the end (and slightly cracked … nothing a little solder won’t fix). Is the end supposed to be flared where it makes contact with the powerhead, or do I need to fix up the end?
      Thanks,
      JP
      #22119
        yes and an o ring goes under it.
        #22121
        jpatti75
          Thanks, Dave. The o-ring is missing so I’ll add one. I also have a little round gasket, that I assume goes between the copper and the powerhead?
          #22129
          green-thumbs
            On rare occasion the water tube may require replacement. In that event deflare the tube and
            draw it out the bottom of midsection. Use the old tube as a pattern to bend replacement tube
            Allow a bit extra length at both ends of replacement tube. Installing tube in exhaust housing
            requires a bit of wiggling. Once in place cut to length and flare upper end. Make sure tube
            does not interfere with drive shaft. Lower end of tube can then be adjusted for length.
            I have done this on WD4 and it should be about same on KE4 with exception of the rubber
            adapter into gear case.
            Not often needed but not a big deal. Helps to lay old tube on board and tack a pattern
            of wood on board to form a channel to mold new tube into.
            Louis
            #22143
            jpatti75
              Thanks, Louis. I did a little solder on the flare this afternoon, and I think I have salvaged it.
              On my question on that little gasket, I don’t think it is actually applicable. With the o-ring under the copper flare, and the powerhead gasket above, I don’t see where it would fit, unless I am missing something here. Anyone have any guidance on that little round gasket?
              #22144
                You are correct.
                #22154
                green-thumbs
                  Manual does not show an "O" but does show the small sort of round gasket. My guess is the
                  clever native craftsmen discovered another and possibly better way to skin the cat.
                  Louis
                  #22159
                  jpatti75
                    quote green thumbs:
                    Manual does not show an “O” but does show the small sort of round gasket. My guess is the
                    Louis
                    Yep, agreed. I’m going with the o-ring.
                    #22208
                    green-thumbs
                      If anyone is interested I can send a photo of the device to guide bend of replacement
                      water tube. Simple to make and very helpful.
                      Louis
                      #22212
                      Doug Wilson
                        If you use the gasket does it go below the gasket or above up against the power head. Power head kind of looks like it may have a small step in it.
                        Doug
                        Doug
                        turned off?
