Home Forum Ask A Member Mercury KG 7 high speed jet
  • #263743
    Francis Cyr
      I’ve got my Kg 7 idling well in the tank.  Low speed 1.5 turns out.  Where should i start on the high speed screw?
      #263749
        about the same.
        #263752
          Had a Kf-7 on the boat a couple weeks ago.
          Settings I made in the tank weren’t even close.
          Be sure to have something to make adjustments
          when you get on the water.
          #263771
          Jorzo211
            Same here with a mark 7. I warmed it up in the tank and made the pre adjustments. Once out on the lake I had to move it CW to about 3/4 out on the high speed and about 1 full turn on the low.
            MARK-7, KF-7, KE4-A, MARK 15, WN7A, (60)MERC 200
            • This reply was modified 3 years, 8 months ago by Jorzo211.
            #263777
            Francis Cyr
              Thanks. I’ve got it on a hydroplane and I can’t adjust it while underway.  I’ve got it about 1 turn out and was afraid it could be a bit lean.  Next time out I’ll try making 1/4 turn adjustments.  I’d rather be a bit rich.
              #263781
                Add a knob OR solder a penny in the slot then you can reach back without looking and adjust. just like the old day racers did.
                #263782
                  Took an old screw driver and ground down the tip
                  to fit. Got a piece of tubing from the hardware store
                  and cut it so the tip was in the slot when the tubing
                  was all the way on the mixture screw. Then epoxyed
                  the tubing to the screwdriver This thing was happy
                  with the high speed out½ a turn and the low out 4 turns.
