Home Forum Ask A Member flywheel
  • #235435
    Francis Cyr
      • This topic was modified 4 years, 11 months ago by Francis Cyr.
      #235459
        More information required!
        green-thumbs
          KF7 and some KG7 had the ribbed prop shaft with alternating fibre and stainless steel disc clutch. If yours has the clutch the clutch may be slipping as designed.
          Mercury Service Tool Catalog shows two tools for holding flywheel when
          removing or installing ratchet nut. M-60-5167 is for KG7
          M-60-591 used for those models having auxiliary starter plate mounted
          on flywheel.
          Flywheel holding wrench OR a work around to hold flywheel might
          be what you need. Catalog was posted at one time, If it is still up
          you may be able to fabricate something workable.
          Stressing everything between prop and flywheel may not be a good
          idea.
          Louis
          #235573
            still don’t know what the problem is. no info up there.
