Home Forum Ask A Member Mercury Mark 20 fuel pump conversion
  • #9513
    ronboonville
      Can I use a Mark 25 fuel pump on my Mark 20 to use a single line tank? Do I need to change the receptacle to do this or just plug one fitting?
      #73188
        yes and yes on both ???????? I have a single line connecter for the mark 20 .
        #73190
        chinewalker
          You wil need to find a fuel pump base from a mark 30/55 as the mark 20 doesn’t have the recess behind the mount to allow the diaphragm to flap. Also, because of the added thickness, you may need to countersink the holes in pump housing for the mounting screws, as they’ll hit the cowling.
          #73207
          SCOTT BOGUE
            Not to set aside this good advice, but contact Joe Poole at Ferguson-Poole if you need parts. And advice.
            #73220
            ronboonville
              Thanks for the help Dave, chinewalker and auldscott. Joe pool was a tremendous help on my other mercs.
