Home Forum Ask A Member Mercury Mark 20 Steering
  • #302459
    Aidan Smith
      US Junior Member
      Working on a Mark 20.
      I was wondering if I am missing any of the parts to run a remote throttle and steering system.
      I have the cage for the front of the motor, and the cut out for the timing/throttle advance.
      I just don’t see anything in relation to the shifting linkage. If anyone has ever set one of these up, please let me know.
      1921 Elto Light Twin F
      1950 Mercury KF-7
      1951 Mercury KG-7
      1959 Mercury Mark 6A
      #302464
        on the hoop is the mount for the cable and on the shift lever is a hole for the cable end.
        #302470
        Aidan Smith
          US Junior Member
          Would you recommend a single or dual lever control box for this? I’m unfamiliar with the remote controls for early Merc’s.
          1950 Mercury KF-7
          1951 Mercury KG-7
          #302503
            either would work. I would use 2 levers to be more original.
            #302528
            outbdnut2
              I recommend a 2-lever remote box. If it’s not idling perfect, and/or if the idle is sometimes a bit uneven, you can increase throttle slightly to get a good speed to shift at so the motor doesn’t kill. Sometimes this is handy when the engine is cold to be able to give a bit more throttle for shifting. If you are running on a hydroplane, I’d just use a spring-loaded dead-man’s throttle for safety reasons, and no remote shift, as you can just reach back to shift it.
              #302540
              Aidan Smith
                US Junior Member
                Dave,
                That’s what I am thinking. I have a dead-man’s throttle and cable tied to a KG7, but I can just as easily make one for the Mark 20. I’m just not sure how the cable would run for the throttle.
                1950 Mercury KF-7
                1951 Mercury KG-7
