Home Forum Ask A Member Mercury mark 25 fuel consumption
  • #7056
    cheetahgod
      Will a 3 1/4 gallons gas tank be sufficient enough for a 11ft class b uitility with a mark 25. What is the fuel consumption on a mk 25 like?
      #57942
        more than enough for your B Utility. even at full throttle .
        #57951
        chinewalker
          By the rule of thumb of a gallon per hour at WOT for every 10 hp, you should be fine for a couple hours anyway. The rule of thumb is variable, to say the least. Best bet, I used to tuck a quart bottle of mixed fuel in a safe spot as a get me to shore reserve. If you’re just running around your cottage or the ramp, you’ll be fine. If you’re exploring, it’ll be enough to get you to shore.
          #57982
          cheetahgod
            Not sure which size would be better?
            #58029
            cheetahgod
              Any other options?
              #58032
              William Jatzek
                Yes just pick up another fuel tank and have 2 on board. Bill.
                #58047
                chinewalker
                  Chances are, on a B utility, you’ll give out before your fuel does. They can beat you up a bit, especially if there’s traffic on your waterway. Best option, run it and see how much it uses. Bring a measuring stick if you have to and run it for a half hour. Check your level to get a feel for how much you’re using. Every rig is different. If you have the stamina for long runs, get a bigger tank or a second tank if you feel you need it. Not sure we can definitively say you need X or Y as we don’t know your situation and how far you plan on going away from your dock.
