THANK YOU FOR THE REPLY. I HAVE AVOIDED INSTALLING IT THE WAY YOU DESCRIBED BECAUSE I HAVE ALWAYS BEEN OF THE UNDERSTANDING THAT THESE BELTS SHOULD NOT BE CRIMPED OR TWISTED EXCESSIVELY. IN ORDER TO INSTALL THE BELT  AS YOU INDICATE, IT REQUIRES A VERY SHARP BEND AND TWISTING MANEUVER THAT I FEAR COULD TEAR THE CORDS OF THE BELT. IT HAS TO BE PUT IN PLACE BEFORE THE STATOR IS INSTALLED (MINE IS AN ELECTRIC START) AND THAT REALLY LIMITS HOW MUCH THE BELT CAN BE FLEXED. IF THE STATOR WERE NOT IN PLACE, IT WOULD BE AN EASY JOB, BUT WITH IT TO CONTEND WITH, THE JOB  BECOMES MUCH HARDER. MAYBE THE BETTER QUESTION IS: AM I CORRECT IN MY UNDERSTANDING OF THE CRIMPING AND TWISTING ISSUE WITH THESE BELTS? IF THEY CAN TAKE THE ABUSE, I CAN DO IT AS YOU DESCRIBE AND SAVE MYSELF THE GRIEF. I WOULD APPRECIATE YOUR THOUGHTS.
