Home Forum Ask A Member Michigan prop info
  • #2452
    wiscoboater
      Hi Guys,
      Was hoping someone would have knowledge of older Michigan prop numbers. The prop I have is a 2 blade solid brass, Lettering on it reads Michigan, then AJC 201. The prop seems to have significant pitch to it. Can anyone decipher the numbers on this and tell me what pitch it is?
      This is a pin drive prop, 8 1/2" diameter that was on a 56 Johnson 10hp when I got it. I want to run this on the FD 21 on the back of my little wooden gentleman’s racer.
      #23227
      ftruntz
        Go to AOMCI Members only on the green board. There are Michigan wheel catalogs 1944 to 1999 that you can access and look you prop up.
        #23228
        wiscoboater
          In all my time as a dues paying member here I have never been allowed access to the inner sanctum or the green boards. It denies me access every time even though I’m a dues paying member. Webmaster help?
          #23229
          wedgie
            Someone here recently posted a link to a batch of original catalogs of Michigan wheel prop applications. Be darned if I can find it in my bookmarks though 🙁 Will keep looking 😉 .
            #23230
            JOHN D.
              2 blade brass prop. 8 1/2 X 11.
              #23232
              wiscoboater
                Thank you all!
                #23235
                beerman57
                  Should be great on an 18hp on a light boat.
