Drifter – I’ve used Permatex Aviation Gasket Sealer in all of my outboard rebuild projects and also used it for years before that on my everyday boat motors and aluminum block car and truck engines with no problems. If you find the Technical Data Sheet for the Aviation sealer on the Permatex website, it indicates it can be used on marine engines. I’ve not used it on outboard cylinder head gaskets only because every replacement head gasket I ever used was marked USE NO SEALER.
