Home Forum Ask A Member Minimum Voltage?
  • #3951
      Several of my motors have dead magnets so I’m thinking of hooking up a battery of some kind to see if they will spark. Any idea of the minimum voltage needed to fire a coil?
      I’ve seen a YouTube vid of a motor running on a nine volt battery and I do have a holder for three AA batteries which will make 4.5 volts total. I’m not sure if that’s enough or not.
      #34212
        Jim,
        That is easy! I have used a vibrator out of the MOT & set up a coil driver. Bet with sufficient current it would work on 3 volts D.C. Need to have a good ampere supply to saturate the primary windings more than higher voltage. I don’t think even "D" sized battery will last very long. Example: Set up flashing L.E.D.s for a fake candle inside a repo looking wall clock. Even the LED load depleted the "C" sized battery after 36 or so hours. Bet you need a small 6 volt motorcycle (Scooter) to supply the needed amperes just like the early outboards. The coils draw around 2.5 to 3 amperes readings on my Merc o Tronic meter. Do something trick like use a photovolatic cell to charge the battery while stopped to fish using the lead acid cells in that battery.
        Or a few to get a fast charge.
        #34213
          I have seen spark with 3 volts in a buzz box I have. I think flywheels create 6 volts.
          #34215
            Mumbles, I can’t say for certain, but I seriously doubt your three AA batteries will supply the current (amperage) needed. I’d suggest a lawn tractor battery. Small, light, and rechargeable.
            #34216
            mercuryman
              My Merc O Tronic take about 2 amps @ 7 volts to fire a coil.
              #34220
                OK, thanks guys!
                Maybe I’ll try a six volt lantern battery when the time comes. I’m a little bit leary of hooking up a 12 volt battery to a magneto coil. I just want to bench test some mags, not take them out on the water, just yet.
                #34222
                  A simple resistor takes care of the voltage issue. But a lantern battery makes sense too.
                  #34224
                  bh
                    Chrysler cars, prior to CDI always used a stand alone ballast resistor that Ford guys said was because MOPAR were too cheap +/- stupid? to switch their coils to 12v from 6V,
                    so attached the resistor when they went to 12v batterys mid ’50s . .
                    In fact it was to allow 12v at the coil while starting, and 6v when running.
                    Quincy loopers using battery ignition used them also, and some early 6 cyl Mercurys ?
                    They should still be availabe at a NAPA store, cheap?
                    Use one in-line with a 12v wet cell battery. A dry cell lamp battery
                    will not supply the current for long.
                    We used big 6v ‘Hot Shot’ or ‘fencer’ dry cell batterys with the PR’s etc in racing .
                    Doubt they are still available .
                    #34229
                      OMC battery & coil ignition on 1960’s V-4’s had the ballast built in to a special "1 ohm" lead from the battery to the coil!
                      #34249
                        • This reply was modified 7 years, 4 months ago by Tubs.
                        • This reply was modified 5 years, 1 month ago by Tubs.
