Home Forum Ask A Member model 310 Senior Speedter timing
  • #10648
    dmbono
      I just ran this motor for the first time- and started it with difficulty. I think the timer is too far advanced. It is hard to bounce the flywheel back enough to fire the timer. This is the current setting. The motor is at TDC with the knob facing you at 6:00. I set the timing lever at 6:00. The timer fires when the knob is about 1-1/2" BTDC. Is there a factory recommendation?
        • This reply was modified 7 years, 3 months ago by Tubs.
        • This reply was modified 4 years, 11 months ago by Tubs.
        #80004
        dmbono
          It was starting in reverse. Thanks Tubs for your reply
          #80022
            #80023
            dmbono
              Changing the timer position didn’t work. It wouldn’t even trip.
              I have discovered that the timer strap is very worn. I’ll make up a dummy that has adjustable hole centers, and try to dial it in.
              #80024
              dmbono
                #80040
