Home Forum Ask A Member modern pump 1956 10hp
  • #225272
      I installed a square pump to convert a 10hp but was wondering if by drilling the 1/4 ” hole in the side cover plate in the center (for a vacum pulse to the pump) if by any chance fuel-oil mix could fill the cavity behind the aluminum plate
      would it be better to also drill a small drain hole at the bottom of the original cover palte so that any accumulated fuel-oil mix could drain/sucked back into the crankcase void instead of “filling up” behind the new plate and enterring the back side of the pump ?
      IMG_0106
      Joining AOMCI has priviledges ๐Ÿ™‚
      • This topic was modified 5 years, 3 months ago by JACQUES.
      • This topic was modified 5 years, 3 months ago by Mumbles.
      #225279
        You could fill the original cover with epoxy or Bondo before drilling a small hole thru it. That would accomplish the same thing.
        #225293
          I’m confused….Are you saying you used another bypass cover gasket between your aluminum plate and the bypass cover to seal that area? If so, I would follow Mumbles’ advice and just fill in that entire area, then drill the small hole through it lining up with the hole you have already drilled.
          Perhaps you can find a 10hp bypass cover from a 60 or newer 10hp that has the fuel pump mounting already cast in place…
          #225294
            Rethinking it, I don’t see why a small drain hole, 1/6″ or so, wouldn’t work as it and the pulse hole would both feed to the same intake runner.
            • This reply was modified 5 years, 3 months ago by Mumbles.
            #225300
              Mumbles: Well I sealed up my aluminum plate to the cover plate with gasket goo (no gasket per say) so I think i’ll go with a small 1/16 3/32 hole in a bottom corner . Maybe I am overly worried. IF the engine performance seems affected for some reason i’ll just take everything appart and fill the cover void with epoxy
              Fleetwin: I agree a bypass cover would be nice but I am just trying to keep costs as low as possible seeing I’ll resell the motor when opportunity knocks .
              I just fix them up (electricals, coils if needed, etc… impeller, timing, plug wires boots etc.. and of course the carb.
              I sell them at my cost plus parts $$ time is on me …4-5 hours on these is like a golf game to me. ๐Ÿ™‚
              thanks for comments
              #225301
                I do what Mumbles suggested (fill it with JW Weld). In theory, that open cavity would add a few cc to the crankcase volume and affect engine performance, but you probably would never notice it.
                #225303
                  OK …then JB weld it is…i’ll do it now before the goo sets to hard under the aluminum plate !
                  update 17:00….hrs done
                  • This reply was modified 5 years, 2 months ago by JACQUES.
