Home › Forum › Ask A Member › My latest $50 find
- This topic has 21 replies, 11 voices, and was last updated 4 years, 9 months ago by
lindy46.
May 19, 2021 at 4:16 pm #238604
I wouldn’t normally buy 40hp motor – too heavy for this old guy – but for $50, I couldn’t resist. Complete 1968 Johnson motor with wiring and remote throttle/shift unit. Appears to be a low hours motor in good shape for 53 years old. Turns over, has compression – that’s about all I know so far. I needed another project!
May 19, 2021 at 4:24 pm #238607At only $50, that looks like a great find! Hopefully, you’ll have it running in short order.
"Every time you remove a broken or seized bolt an angel gets his wings."May 19, 2021 at 4:34 pm #238610She likes gasoline. Uh, she LOVES gasoline and lots of it !!!! You’ve been warned.
May 19, 2021 at 5:44 pm #238620She likes gasoline. Uh, she LOVES gasoline and lots of it !!!! You’ve been warned.
Yeah I’ve had several of them in the past and they’re not as thirsty as my old Sportfour 60hp. I really have no use for the motor so I’ll get it running and sell it. I just enjoy working on them. Preserving the old iron.
May 19, 2021 at 5:53 pm #238621beats all my deals !! great find
May 19, 2021 at 6:22 pm #238622Outboards keep you young, all that “thinking” and tinkering, …….. until you go to lift them!
May 19, 2021 at 9:31 pm #238627I see wires hanging out the front — is it electric shift ? If so, the solenoid coils in the lower unit are not tolerant at all to moisture — I would test those before any other item on the motor — not sure how easity it is to find replacements .
May 19, 2021 at 10:47 pm #238630This is a manual shift engine. Looks to be in real nice condition also
May 20, 2021 at 11:06 am #238662Yes manual shift. I drained the oil – no water. I then pressure tested the gearcase and she held fine. No seals to replace. I broke off one of the small studs on the starter solenoid in my attempt to clean up all the wires/connections. So once the new solenoid arrives I should be able to turn her over and get a compression reading. If it’s got good compression, I’ll attack the flywheel. I hate these 40’s with their 105 ft/lb torqued flywheels – always a challenge.
May 20, 2021 at 11:38 am #238663try a 1/4 inch impact driver …you may be surprised
