Home › Forum › Ask A Member › My latest $50 find
- This topic has 21 replies, 11 voices, and was last updated 4 years, 9 months ago by
lindy46.
May 25, 2021 at 12:28 pm #238968
Well I finally got a new starter solenoid and the starter works great. However top cylinder compression is only 95psi. Bottom is 110psi. I sprayed some Deep Creep and fogging oil in cylinder – see if that loosens up the rings. If not I guess a head gasket is the next step. On the positive side, strong spark on both cylinders.
May 25, 2021 at 7:41 pm #238991Got the compression up to 106psi. I’m going ahead and change the impeller and rebuild the carb. Anyone know part number for a carb Kit?
May 25, 2021 at 7:57 pm #238992Carb kit is OMC 439075 or Sierra 18-7024. The Sierra kit, however, does not include a new float.
"Every time you remove a broken or seized bolt an angel gets his wings."May 26, 2021 at 9:21 am #239011My latest $50 find is a Mercury KF-7 lower and clamps ass’y. It’s weight is similar to the cover of your Johnson ! !
May 26, 2021 at 9:35 am #239012My latest $50 find is a Mercury KF-7 lower and clamps ass’y. It’s weight is similar to the cover of your Johnson ! !
Heh Heh – yes the 40hp weighs about 140 lbs. I’ll bet the cover is 20 lbs. Any $50 find is a steal nowadays. I remember about 20-25 years ago finding $50 motors all the time.
May 27, 2021 at 6:22 am #239057The cover for that 40 doubles a a life boat.
May 28, 2021 at 10:06 pm #239167This was a quote.
She likes gasoline. Uh, she LOVES gasoline and lots of it !!!! You’ve been warned.
Not to change the subject But do these 40 horse Evinrude/ Johnsons from the early 1960’s and later use considerably more gas than than the 1950’s 25 to 35 horse model big twins?May 29, 2021 at 12:42 am #239169My buddy was head of the propeller and engineering at OMC he had worked for Mercury in the early sixties he said they took the hood of one of the biggest OMC motors and plugged all the holes to make it water proof .They put a 5 year old kid in the hood and took a picture of the kid paddling the hood on the lake.They mailed the pictures to OMC for a laugh.
June 2, 2021 at 12:59 pm #239391Well, I changed the impeller, rebuilt carb and fired her up. Started immediately! And idles good. However she’s not pumping water. I removed the thermostat cover, and no thermostat. Started her up but no water getting to the thermostat chamber. Not sure where the problem is at this point but at least she runs. I ran some wire down the inlet but that seems clear. Probably time to pull the lower unit again.
June 2, 2021 at 5:13 pm #239401Rookie mistake – leg not deep enough. Raised the water level (had to raise the drum) and she pumps fine. However the head is VERY hot – hot enough to boil water. So I pulled the head and all the passages are clean as a whistle. So I’m stumped. This motor has another cover over the head – not sure what that’s all about. Could that have anything to do with the cooling problem?
