Home Forum Ask A Member NEED 35 hp/40hp carb
  • #182624
    JERRY SMITH
      need to find a good carb rebuilding a 1959 Gale I think a 35 hp evenude lark would work please let me if I’m right laluzsmitty@yahoo.com 575/491/2616 thanks smitty
      #182631
        I believe you are right. There are a lot of parts that are interchangeable between the two. What is wrong with the carburetor on your model?
        #182665
        JERRY SMITH
          hi garry rebuilt carb has great spark fuel bowl full no fuel to the plugs what should I check thanks smitty
          #182687
            If there is fuel in the carb bowl, it would be nearly impossible for it not to go on through (as a carb fault). You could throw a screaming cat through those big passages. I suggest you get your eyes off the carb and look elsewhere. Have you actually looked at the ignition? “Good spark” doesn’t impress me at all. Cracked coils will give a spark but not run worth a hoot.
            You have checked the compression, haven’t you?
            BTW, wet plugs would indicate flooding, if that is what you are looking for.
