Home Forum Ask A Member Need Help / INFO
  • #4827
    joe-smerc
      Have old Evinrude 4 cyl oppossed motor…4859 12111 … ??? WHAT IS IT ??? 1 coil lead puts out juice … all others dont feel a thing.
      At First… thought it was weak magnats… Nope …feels strong pulse when cranking. Anyone have extra coils for Sale ??
      How do you test for bad coils? Managed to get 3 other project motors to fire .. Happy Day for me.
      Thanks cb seattle
      #40788
      JOHN D.
        It may be an Evinrude Zephyr made in 1940-41. The model number on that one is 4359. It’s 5.4hp motor.
        #40791
        wedgie
          Does it look like this?
          #40793
          2fast4me
            Hello cb, ohmmeter resistance readings will be very low for primary coil resistance with the points open of about 1ohm to ground. You can test this without disassembly. The secondary readings will be about 8k or 8 thousand ohms and that will be measured from lead to lead on the top cylinder, same for the bottom cylinders. No or high reesistance to ground. It sounds to me like one lead is shorting to ground on the one that is firing. The other could have poor connections in the points, standard troubleshooting rules apply.
            2Fast4Me
            #40904
              I wish you had posted on the Dockside chat – I can post pictures directly from my computer their …
