1 more problem did not think i would have a issue but the spark plug is a 2 part assembly tappers to a point is this some type of heat plug its a champion c7 has continuity is this a original one and continuity thru the spark plug wire but no spark points ring coil rings out capacitor has 11.00 something but wont even puff i am thinking its the plug is there any other type of you might try the plug is older than i am never seen one like it thanks again for your input at least i have a starting place have a good one
