Home Forum Ask A Member Neptune Mighty Mite water pump
  • #210290
    todd281
      I have a Neptune Mighty Mite model 11a1 . It is up and running well now . I need to know how to confirm that the water pump is working. My understanding is that these small motors need to have the return line from the head to the gear case in place and sealed for the pump to work , that the gravity on the return line helps the pump work [ no real head pressure needed] That line exits very near the prop and underwater so there is no visual way to see if its pumping. Any ideas would be welcome
      #210298
        Because of the siphon system as you just described, there is no above water water outlet. If it stays cool, it is working. Fortunately, the centrifugal pump does not wear out.
