Home Forum Ask A Member Neptune questions
  • #1620
    Doug Wilson
      I am working on a 2hp Neptune 15B2 that was recently given to me. Not sure which jet is which on the carb guessing the larger winged on is high speed and the smaller one going through the intake cover is low speed. Any suggestion as to what approx settings to adjust to when I try to start it.
      I know will have to fine tune when I get it running.
      The other question is about the impeller, is it one that needs to be replaced?
      Thanks,
      Doug
      Doug
      turned off?
      #17087
      RICHARD A. WHITE
        It has the metal impeller, I think, so no worries there, as for carb settings, try 1 1/2 and 1 see what it does….
        classicomctools@gmail.com
        #17144
        Doug Wilson
          Thanks Richard will give that a try, carb is done and coil is supposed to be coming in today
          hope to give it a try this weekend then get to either the super 10 Wizard or Johnson K-50
          Doug
          Doug
          turned off?
