Home › Forum › Ask A Member › New 302495 Oil Seals OMC 10-18HP ’51 to ’57
- This topic has 32 replies, 9 voices, and was last updated 3 years, 1 month ago by
seakaye12.
February 27, 2018 at 7:10 am #71679
Hi Chris,
I just wanted to see if you had a chance to look up the model # and Serial # on my previous reply regarding the Prop shaft seal, any help will is greatly appreciated. Thanks CesarFebruary 27, 2018 at 5:27 pm #71694Your info needs to be on a "sticky" someplace.
February 28, 2018 at 9:42 pm #71734quote cesarp35:Thanks for getting back Chris, i purchased the Sierra 18-2684 and My 1957 Evinrude 18hp is model 15020 Serial# 27598 i haven’t taken the lower unit apart just yet but i wanted to be prepared in case the Sierra 18-2684 prop shaft seal is not the correct one. Thanks!So sorry did not see this!
You are lucky. The 18-2684 should have the correct prop shaft seal for you. This kit will serve the 1957 18hp Evinrude above serial number 22000 as yours is. So that is good. If it were lower than serial number 22000, the prop shaft seal would not work. As there was an engineering change mid year 1957. Sierra does NOT make a seal kit for the ’51 to ’57 10 to 18hp OMCS, as they do NOT have a replacement for the 302495 oil seal.
Hope this helps.
February 28, 2018 at 10:43 pm #71738That is good news!!!! Thanks so much Chris for getting back and for taking the time to look into this for me i really appreciate it, i’m sure it’s going to help a lot of other people that find themselves in this situation, again Thank you!!!! Cesar
July 3, 2021 at 4:46 pm #241875Hi, Chris,
Do you still have any of these? If so, what is the current price and shipping and how do I pay for it? These seals look really nice. I would be installing one on my 1957 Johnson FD-11 18 hp. which I just got running yesterday. My parts catalog shows it to take a 302495 seal. You can reply to me here or via email: timpuckett761@yahoo.com Thanks, Tim.July 3, 2021 at 8:28 pm #241896xxx deleted
This reply was modified 4 years, 8 months ago by
JACQUES.
July 3, 2021 at 9:12 pm #241899Chris’ will you be at either Constantine or Tomahawk this year? If so….will you have ample stock of all your seals?
July 4, 2021 at 12:26 am #241902Chris hasn’t been active here for over a year now but his website is still up!
July 4, 2021 at 6:58 am #241907Thanks, Mumbles. I appreciate the help. I see that he has a gearcase seal kit which would be perfect for my needs. I tried to send an email to Chris on his website, but the message doesn’t seem to be sending. If he is no longer active, are you aware of anyone else here at AOMCI that sells similar parts? Thank you very much for your time and have a great day. Tim.
July 4, 2021 at 11:16 am #241925Thanks, Mumbles. I appreciate the help. I see that he has a gearcase seal kit which would be perfect for my needs. I tried to send an email to Chris on his website, but the message doesn’t seem to be sending. If he is no longer active, are you aware of anyone else here at AOMCI that sells similar parts? Thank you very much for your time and have a great day. Tim.
I’m having the same issue…Oh well
