Home Forum Ask A Member New member just bought a 1956 Wizard Super 10
  • #5631
    flatbottom-kevin
      Hi everyone, just picked up a ’56 Wizard Super 10 WM7A. It is in rough shape but starts. I am looking for some parts, not sure if I am going to do a full restoration or just make it a nice looking reliable runner. Any help with finding parts would be great. Thanks.
      #46998
      PugetSoundBoater
        Hi Kevin, welcome to AOMCI. Our club has many folks here that can aim you in the right direction to get parts for your Wizard, and information on repair procedures. There is a free classifieds section, read the posting guidelines before posting. You have to include WTB ,your location and contact info.I’m sure someone will be along soon with some sources for your motor.You will find a lot of knowledegable help here .EDIT spellcheck
        Robbie Robertson
        #47000
        flatbottom-kevin
          My mistake, I was more just saying hi to everyone and looking for places to search at than looking for specific parts, yet. I put my location on my profile but guess it isn’t showing under my name. I am located in Murfreesboro Tennessee. Thanks for the correction.
          #47005
            join johnsoldmerc.com for merc and wizard.
            #47007
              Lots of helpful sites posted here on our forum
              viewforum.php?f=41
              #47015
              Doug Wilson
                A lot of the Mercury parts are the same as Wizard cylinder bore on some of the Wizards are a little smaller not sure if the WM7A is smaller or not. All the ignition, carb and impellers are the same for sure. I have a WG7 which runs real strong and picked up a WH7 that is in line behind the KE7 Mercury on the bench now. Old Mercs and Vintage outboard have most parts hand grips Doug Penn has. I agree with Dave Bernard join johnsoldmerc. There is plenty of info and help here too but the Mercury experts are there and there is a separate section for Wizard. Also a Wizard outboard forum too, it will tell which mercury model parts cross to which wizard. Reprotint has paint that should match.
                Doug
                Doug
                turned off?
                #47020
                chuckw
                  I also just picked up a WM7A which needs some work . Swivel pin is stuck beyond repair and the lower unit needs work, so I am looking for some parts. Can you post pics of your motor? The cowls on mine came through cracked in the back. I think the bottom can be welded, but need the top cowl which is missing the cowl part hook up for the fuel line which was broken. Also looking for a saddle.
                  #47033
                  RICHARD A. WHITE
                    quote chuckw:
                    Chuck, can you PM me? Might have what you need…
                    classicomctools@gmail.com
                    #47034
                    jw-in-dixie
                      "Swivel pin is stuck beyond repair". Have you turned the motor upside-down to see if you can use a pin punch to drive the pin out? May have to make a punch. Seems like I got one out by running a screw into the top of the pin for the punch to strike on, then applying force with a large "Mercury Special Tool" (see illustration) vigorously. Lots of pre-soak with your favorite penetrant. Good luck. JW
                      #47036
                      green-thumbs
                        Steel swivel pins stuck in aluminum swivels "beyond hope" are a can’t hurt might help situation
                        With nothing to lose you can use the nuclear option…TORCH…fabricate the "Mercury Service Tool from threaded rod, pipe, nuts and washer. Install on swivel pin and apply tension.
                        Then HEAT the swivel in the area of the pin…LOTS of HEAT and some twisting of nut to increase pressure. There can be only two results…one is GREAT and the other leaves you
                        no worse off. If it does not work you may have to saw thru pin to remove swivel from
                        saddle. Once unstuck swivel and pin may be good enough to use.
                        Louis.
