Home Forum Ask A Member new-old evenrude owner
  • #263969
    MacGuy99
      Just bought a 4 HP Evenrude and I don’t know a thing about it. It is a model 4836E which is a 1978 but I don’t even know if it is a 2 stroke, or as the guy who sold it to me said, a 4 stroke. Any help on startup would be appreciated.
      #263972
        It is a two-stroke!!!  Fuel mix is 50:1, or 1/3 pint per gallon, using TCW-3 outboard oil and 87 octane gas.
        #263973
          MacGuy99
            Thanks, I was pretty sure it was but needed confirmation. It cleaned up well and has spark so I guess I need to get a tank and mix some gas to see what else I have.
            #263978
            reivertom
              Just hope the Previous owner didn’t run it! If it has decent compression, you are OK. Nearly everything else can be pretty easily fixed.
              • This reply was modified 3 years, 7 months ago by reivertom.
              #263987
              wedgie
                Be careful with the starter. They are prone,  and not easily replaced.
                • This reply was modified 3 years, 7 months ago by wedgie.
                #263995
                  Yes, those side mounted rewinds are very delicate for sure. Pull the rope gently until the gear engages the flywheel, then give it a short yank. Avoid releasing the rope and letting it snap back in on its own, this will mess up the spring. Avoid pulling the rope out too far, this will damage the spring and pulley as well.
