Home Forum Ask A Member New project 1-14 Scott Atwater 501 4 hp needs coil
  • #3649
    fishingnuts
      Its a Wico coil that has a 9/16 to 5/8" center, I can find a coil for the smaller center 7/16" square, so if someone has the smaller I buy it. Or if you know where I can find a replacement for the older one. Also looking for diagrams of the motor, upper and lower.
      Thanks, Ed
      #32064
        Can’t seem to get diagrams loaded, but the Wico number for the coil is X7120 (Scott Atwater # 501-113)
        #32066
        fishingnuts
          Thanks for the part number, will try and find one.
          I found out that the early coils had a 5/8" square hole and the late models had a 7/16 square hole. Getting that check out now. Also need the part numbers on the points and condenser.
          #32072
            Condenser is X-5463, capacity is 0.16 – 0.20mfd. (Scott # 463-115) Points are Scott # 503-127. I have the cross reference # "somewhere".
            #32077
            fishingnuts
              Been surfing looking for the parts, might have found the coil, haven’t had any luck on the condenser.
              Thanks for the numbers,
              I will keep looking.
              #32084
                I think the points are X-7046. Don’t have pictures to verify.
                try martinoutboards.com. Martins use some of this stuff too.
                #32099
                  Do these look right?
                  viewtopic.php?f=3&t=5538
                  #32101
                  fishingnuts
                    Found all the electrical parts. Now looking for the water pump impeller. Was given a part number of 493-5100. Still surfing for it.
                    Thanks for all the information, really been helpful.
                    #32105
                      Shucks, impellers are the easiest part. This clubmember makes them
                      http://home.earthlink.net/~flyingscott/index.html
                      #32106
                      fishingnuts
                        Thanks
