Home Forum Ask A Member Newbie Tool Must Have
  • #298683
    Michael Zampini
      Tool I use the most. Seems like most every day it comes in handy for something.
      Tool-I-use-the-most
      Thanks!  I have an entire set of these with my gunsmithing set!
      thanks-mz
      #298684
      Michael Zampini
        A good handheld impact driver and associated bit set is one of the most important tools for this hobby.
        Ironically, one of my friends literally just gave me an air pump and impact tool set!
        thanks-mz
        #298685
          I like 1/4 inch  battery impact driver with  adapter to 3/8 drive  socket to remove the FW nut … but it should be torqued to spec on installation.
          A cheap GC  pressure  tester  can test pressure and vacum see video    see amazon around $40
          dangar marine pressure test – Recherche Google
          #298686
            deleted
            #298703
            green-thumbs
              You will always need the tool you do not yet have. Eventually
              your problem will be finding the tool needed to do the job at hand before you forget what you are looking for and why you
              need it.
              Best advice I can offer is when you finish using a took, put it back where you found it so it will take no more time to find it the next time you need it as it did this time,
              A place for everything and everything in its place will save time and trouble,
              Louis
