Home › Forum › Ask A Member › Newbie With A 57 Golden Javelin
- This topic has 16 replies, 12 voices, and was last updated 7 years, 6 months ago by
duralark.
August 15, 2018 at 11:33 pm #81252
Great deal – I paid about ten times more for my Golden Javelin. Your model number says it’s a long shaft motor because it has the "L" in it. That means your boat should have a 20 inch (approximate) transom. Short transoms are around 15 inches. Check what your boat has. If you have a short transom, your motor can be converted to short shaft with the right parts. If you run a long shaft motor on an short transom boat, your performance will suffer because it’s like dragging a big club through the water. Dealers sometimes converted motors form short to long and long to short when inventory of one was out, so check what you really have. If in doubt – post a photo of the lower half of the motor and we will tell you.
DaveAugust 16, 2018 at 3:06 pm #81292Forth picture in initial post shows a "short shaft" Javelin.
Great deal…running or not!
Mas
August 16, 2018 at 3:31 pm #81296quote Mas:Forth picture in initial post shows a “short shaft” Javelin.Mas
Ah – I totally missed seeing the Javelin lower to the right of the Evinrude in the 4th photo – definitely a short shaft!
DaveAugust 17, 2018 at 12:22 am #81334quote outbdnut2:quote Mas:Forth picture in initial post shows a “short shaft” Javelin.Mas
DaveInteresting… means that someone changed it during its history. Model number has the ‘L’ in it. Good catch guys.
August 17, 2018 at 1:28 pm #81360quote markpj23:quote outbdnut2:quote Mas:Forth picture in initial post shows a “short shaft” Javelin.Mas
It is not very unusual for this change to be made during a motor’s history. I have found that most of the long shaft motors I have had were converted short shaft motors. That includes a ’58 Super Seahorse that began life as a short shaft and now is a long shaft. These things seem to get swapped back and forth as different needs arose throughout the life of the motor.
-BenOldJohnnyRude on YouTube
August 17, 2018 at 2:03 pm #81362Great deal! You don’t need the pressure relief system if you’re using the electric starter. They’re just a bear to pull start without it.
August 21, 2018 at 4:05 pm #81536Man, what a deal! This is my first post here; I’ve enjoyed and learned from reading here. A lot! 2 thoughts on your Javelin: 1) I have a ’57 BigTwin 35 Evinrude that has become a parts motor for my ’56 Lark 30hp. It appears to me that the compression relief system is only intended to make it easier to pull start the motor. I wouldn’t worry about it if I were you, but if you want all that linkage and stuff, it’s available. 2) If the seller hasn’t thrown it away yet, drive over there like a bullet and get all the controls, wiring, junction box, dash panel switches/bezels etc that you can find that go with your motor. Often, that stuff gets thrown out and it can be a pain to find later.
Congrats on your awesome deal! And frankly, it looks to me like the bug has already bit you!
~ Bob -
