Home Forum Ask A Member non splitting l.U. on a 9.5 Sportwin ????
  • #7094
      my new to me 9.5 which came with a CD15 plate 😯 …. has a solid gearcase (non-splitting) like they began around 1974 …an up wards on the 9.9 hp version
      the engine faceplate on the cowl says 9.5 but the solid gearcase speaks 74 and up & according to parts diagrams on that site we all look at
      it is a 9.9 hp
      I never took one of those l.u. apart . I found a few drops of water in the l.u.
      If sealing the l.u is to complicated I may just refill with fresh oil on occasion
      any special procedure/tools to reseal these solid bodied L.U. … & their hard to access gears and seals …
      meanwhile I go surf utube….
      update#1.. I looked at parts diagrams they show a prop with rubber drive core yet my engine has a standard old style drive pin shaft
      it is like it has one foot in the pre 74 world of split gear cases & drive shaft and one foot in the post 74 solid gearcases yet it drives the prop with a drive/shear pin about .185inch diameter by 1.5 inch long
      #58164
      fisherman6
        Is the drive pin near the gearcase or toward the threaded end of the driveshaft? Any way to see a picture of that gearcase. I’ve never seen a 9.5 that didn’t have a split gearcase.
        -Ben
        OldJohnnyRude on YouTube
        #58166
          the drive pin is near gear case at he back of the prop …
          the drive shaft thread hole is for the cotter pin to lock in the prop plastic nose cone
          solid gearcase is typical on 74s and up
          motor came with a full circle prop protector bolted to the cavitation plate and tip of the keel
          #58167
          fisherman6
            The props with the drive pin near the gearcase do have a rubber drive hub inside. Here are a couple pictures of one I spun in my ’59 Sportwin.
            -Ben
            #58170
              thanks I assumed none but was comparing to a more modern version. good to know
              here are pics of my ..odd l.u. on a 9.5
              #58172
                notice plugged holes on cavitation plate i removed the prop protector… L.U is same color as the top but totally filthy dark…
                #58176
                chinewalker
                  It’s a regular 9.5 lower unit. Nuttin’ special.’
                  #58177
                  kerry
                    In that first pic, there seems to be the remains of a seam… Could the PO have welded the case halves together? Could try scuffing some paint off and look for welds, especially the underside where the screws would be…
                    #58178
                      bad day today … clothes dryer timer blew….
                      found the problem … me πŸ™„
                      Kerry sharp eyes spotted that seam… in the photo
                      l.u. is so filty looking down on it….. i did not see those screws …
                      now I can seal it πŸ˜€
