That might be an 8:1 motor…..but no less oil than 16:1….. Some feel less oil because of newer oil, to which I respond, ” How long until your local Caille dealer can get you new parts, “should” something happen due to insufficient oil in the mix”?
You can use pretty much any good quality 2 cycle oil, but consensus is regardless of which oil you choose, keep the manufactured recommended ratio…and that act should prevent any failure to to poor lubrication.
classicomctools@gmail.com
