Home Forum Ask A Member oil slick 2017
  • #7907
    mike n
      hello, i had a post about three years ago about my qd19.i bought it in nice shape and did the usual things to get it running.coils,points and condensers.carb rebuild,impeller.i go to maine every summer and run it on the lake.it ran great but would leave a large embarassing oil slick as i slowed down and got to the dock.i tried changing mixture screw adjustments but it didnt change.i pulled the power head and replaced the dried out o-ring in the carbon seal but no change.last year i took the powerhead apart.i swapped the dump valve from another engine,cleaned all passages , and put a new set of rings on the pistons.i found that this engine has already been apart and has the updated pistons and connecting rods.it still left a big oil slick.this year i got another carburetor and rebuilt it.still a big oil slick.i have a qd17,qd20,qd21 and they hardly leave any oil deposits at all.i’m confused.the engine runs great and does not load up the plugs.could there be too much pressure in the tank?is there a pressure relief valve somewhere.i’m pretty sure i used the same tank on my qd17 with no problem.could there be a problem with the block? i have another block,should i swap the parts over? sorry for the long story.i’m lost
      mn
      #63123
        My 58 Sportwins leave slicks as well…Some guys use synthetic oils which might help, I just use the plain TCW3 stuff from BRP…
        #63203
        mike n
          are there any differences in the 56 and 58 blocks and carbs
          mn
          #63216
          reivertom
            All the old 2 strokes leave some kind of oil trail. If you are worried, use synthetic outboard oil mix. It is more biodegradable and lake friendly. Also look at the current thread about unburned fuel collection. You can find others on the same subject if you do a search.
            #63217
            chinewalker
              2-strokes are dirty. Nature of the beasts… As noted above, there are some things you can do to alleviate the worst of it. Running the motor as lean as possible on the carb settings without running too lean (plugs a nice light chocolate, not white), running the correct fuel mixture, making sure you’ve got the right plugs, etc. can make sure it is running as efficiently as possible.
              #63227
                The Factory recommended mix for Evinrudes Racing 460 was four to one using 60 weight non detergent oil. . . 😮
                #63267
                mike n
                  thanks for the help.i’ll have to tell my friends to go hug a tree when i pull up to the dock
                  mn
