Home Forum Ask A Member Oil slinger, how does it work?
  • #5600
    jerryswiss
      Mid 60’s OMC 5 and 6hp just below the breaker cam on the crankshaft, how does it work? ❓
      #46720
        Fuel mix comes up thru the bearing and creeps up the crankshaft. The slinger throws it off into a groove where it gets sucked back into the motor thru a small passage in the front crankcase half.
        #46723
        jerryswiss
          So is it designed to lube the points rubbing against the cam?
          #46724
            the felt wick does that job dont loose the clip…. $30+
            #46727
              quote jerryswiss:
              The point cam is above the slinger on the crank, so the slinger is not there to help lube the points rubbing blocks/felt wiper.
              #46749
                The exact opposite – it is designed to keep oil OUT of the magneto so it won’t foul the breaker points.
                . . πŸ˜‰
                #46750
                  quote Garry in Tampa:
                  . . πŸ˜‰
                  We are saying the same thing, I just didn’t say it very well…
                  #46751
                    same here πŸ™‚
                    I did not say the slinger oiled the wick I said the wick oiled the rubbing block of the points
                    #46757
                    jerryswiss
                      Got it, this motor is missing the wick. I will rig up something.
                      #46759
                      fisherman6
                        A new oil wick comes with each set of OMC / BRP points. If you are doing a tune up and you get new points (OMC) you will get a new wick and have a second one for a spare.
                        -Ben
                        OldJohnnyRude on YouTube
