Home › Forum › Ask A Member › Oil slingers…ooops no it is not :(
- This topic has 7 replies, 3 voices, and was last updated 9 years, 7 months ago by
chris-p.
August 15, 2016 at 7:53 pm #4987
Love them little buggers…..
1953 Evinrude Super Fastwin 15 hp, model # 15012Parts list I have says part should be.. 301857
I have one with part number 307576…..
It fits the crank, but is it right?
Thanks
classicomctools@gmail.comAugust 15, 2016 at 8:26 pm #42131PN 301857 is not an oil slinger, that is just the washer which contains the spring on its top side.
Also, the model 15012 Fastwin doesn’t use a slinger, it has a carbon seal and o ring assemble on the top of the crank. All the ones that I have seen anyways, perhaps im wrong and there is a variation of the 15012 with a slinger that I haven’t seen before?
Then a 302594 washer sits on top of the carbon seal assembly, then the 203250 spring, then the 301857 washer, then the points cam on top of that.
August 15, 2016 at 8:31 pm #42132So the carbon seal is under that bottom washer?Ok I see the Carbon seal…I had oil on the points…now to get the carbon seal out without breaking that fragile housing…grrr
classicomctools@gmail.comAugust 15, 2016 at 8:39 pm #42134August 15, 2016 at 8:47 pm #42138I got that, apparently I must read THE WHOLE DANG PAGE…LOL
classicomctools@gmail.comAugust 15, 2016 at 8:50 pm #42139That shows 2 o-rings?????
classicomctools@gmail.comAugust 15, 2016 at 10:05 pm #42143quote Richard A. White:That shows 2 o-rings?????Richard, that is correct; but one goes around the bearing. Every one that I had to split the casing open before because of excessive oil going by that o-ring; was cracked. You might have to go in there and do it too?
JerAugust 16, 2016 at 2:20 am #42163Yeah as jer stated, that larger #11 o ring goes around the bearing. You can see the groove for it at the bottom of the bearing in the pic. The #10 o ring seals the inside ID, and goes in the carbon seal. I don’t think there is anyway to do it without splitting the cases sorry.
