Home Forum Ask A Member Oil type
  • #185853
    Samuel Phelps
      Not to start a big debate but which type 2 stroke oil should I use for my Speeditwin . Synthetic tcw-3 ?
      #185862
        If everything is OK (No excessive clearances) Synthetic TCW3 would be great at ⅓ of a pint to the gallon.
        #185866
        Samuel Phelps
          So you mean if it has no excessive clearances / meaning good compression ? Then 1/3 pint synthetic is good amount .. So 5.3 oz per gallon ..
          Sorry if stupid question ..
          #185870
          eltoquad
            1/3 pint per gallon!!!!!???
            #185872
            Samuel Phelps
              I guess with synthetic you don’t have to add quite as much .
              Reg tcw-3 at 16:1 is 8 oz per gallon ..
              #185873
              Tom
                Unless I missed something somewhere, we should probably pin down what model Speeditwin you have. A ’27 Model T Speeditwin, a 6039 Speeditwin, and a ’60’s Speeditwin all have different oil requirements.
                T
                #185874
                Samuel Phelps
                  Sorry its a 1949 – 6039
                  #185876
                    I believe the original spec for the 6039 model was 3/4 pint per gallon.
                    #185877
                    Samuel Phelps
                      That would be 12 oz ..16:1 is 8 oz per gal right ?
                      #185879
                        Yes, 8 oz would be 16:1
