Home Forum Ask A Member Old prop ID
  • #11308
    count
      Picked this up at a flea market only because I thought it was unusual. Diameter is about 8 inches. It’s pretty thin aluminum and it seems to be from a small old motor. I don’t know what small motors used a three blade prop.
      #83454
        Look very closely at the inside of the hub on the circular flat area separated by the shear pin slot for the letters and numbers code. Find the code and I will look up the application .
        #83458
        outbdnut2
          Champion 4LHD models (7.9 or 8.5 HP depending on year) came with a small diameter 3 blade prop that looks a lot like that. Hard to tell for sure from the photos. I have a couple and I can take a couple pics for comparison if I can find where I put them.
            This is a Johnson Motors prop.
            #83493
            count
              I don’t think there are any numbers on it but I’ll take another look tomorrow.
              #83499
                I can make out the letter A.
                #83502
                lyks2tinkr
                  Looks like a prop on 2 of my motors. 1 is a 37 Johnson 110 and the other is a 1940 Champion D2D Playboy.
                  #83504
                  kees
                    International Member
                    quote XR55:
                    FWIW
                    no Johnson prop
                    checked my models and the 3-blads props on my Johnsons
                    are not even close with this one.
                    #83627
                    outbdnut2
                      Below are photos of a Champion prop from a model 4LHD that I mentioned earlier. Comparing, it is a bit different than yours, the main thing being that the slot for the shear pin is recessed on yours.
                      kees
                        quote outbdnut2:
                        this one is " ANTI clockwise " or a left rotating prop.
                        so this is a NO, I guess
                        I have a Champion with a "clockwise " prop, will check tomorrow
