Home Forum Ask A Member Older Johnson
  • #35484
    caelah
      MAYBE THIS WILL HELP EXPLAIN THE REE-KOIL STARTER. HOPE ALL 3 IMAGES COME THROUGH. THANKS[/url]
      [/img]
      #35486
      Doug Wilson
        Agree looks like an A-50 but have never seen that recoil unit before.
        Doug
        turned off?
        #35490
        sailor58
          The model number should be on the rope sheave under that recoil ratchet thingy.
          Larry
          #35495
          outboardnut
            that is a sharp motor-caelah
            #35502
            oldelto
              It is called Johnson Ree-Koil Starter.
              #35503
              oldelto
                Have seen complete outfit on A-50, K-50, and S-45. Also seen pieces for P-50 and V-45.
                #35508
                1-old-outboard
                  There is no plate model number under the Ree-Koil casting. There is a fairly thin aluminum shim washer type spacer and that’s about it. Casting number for the flywheel. No model number or serial number under starter. There is a serial number on the side I think. Photobucket is having a hissy fit at the moment. Can’t call an . The serial number stamped on the side is 158793 I believe.
                  Randy
                  #35510
                  caelah
                    THAT SERIAL NUMBER INDICATES THE YEAR OF MANUFACTURE TO BE 1931. SINCE THE REE-KOIL WAS AN AFTER MARKET ACCESSORY, THERE WAS NO SERIAL NUMBER. I STAMPED MINE TO MATCH THE CORRECT SERIAL NUMBER OF THE MOTOR. HOPE THIS HELPS
                    #35520
                    hotrod
                      Some REE-KOILs had 2 tags which included model number and serial number which matched the one on the crankcase like this early 1931 A-50.
                      #35528
                      1-old-outboard
                        So starting the chase for a Re-Koil, I would have to be looking for a A-50 Re-Koil because they appear to be specific to the engine? What are the chances?
                        Thanks all, a ton of good information.
