Home › Forum › Ask A Member › Older style omc fuel
Need to confirm fuel tank repair kit for tank with older aluminum plunger style 8 hole. Is it 376455?
That is a gasket set only, not a repair kit. Does not contain a diaphragm
Ok is a repair kit available and if not the diaphragm number if possible. Thanks to all who help!
ME shows #377327 diaphragm kit. #305715 8 hole diaphragm & #302563 9 hole diaphragm.
Dan in TN
Buy the 8 hole diaphragm and add the extra hole IF you need it… it is cheaper that way…Buy 1/2 a dozen ….just in case you end up with 7 extra tanks and only one motor that needs a tank…just saying…lol
http://www.richardsoutboardtools.com classicomctools@gmail.com
OK
