Home Forum Ask A Member OMC 2-line pressure tank rebuild kits
  • #9631
    foot_doctor
      I own a 2-line tank that is in need of a rebuild. Where do you folks suggrst that I get the kit from? I rebuilt it several years ago, and it has developed a leak in the diaphram near the primer button. Thanks, R.T.
      #73924
      chas56x
        You can order the kits here: http://www.laingsoutboards.com/johnsone … parts.html
        #73927
        RICHARD A. WHITE
          Or you can order the diaphragm directly from Marine Engine.com as well. Order the cheaper one that is missing a hole, and add it if you need it, instead of paying them to put one in for you.
          After thinking about it, the one with the hole should be for the aluminum push button and the one without the plastic button.
          I will be corrected if I am wrong.
          classicomctools@gmail.com
          #73929
          fisherman6
            You are correct Richard. The hole is for the aluminum push button. The plastic push button does not use the hole in the diaphragm. 😉
            -Ben
            OldJohnnyRude on YouTube
