Home Forum Ask A Member OMC 6 hp–removing carb?
  • #4937
    amuller
      This is almost certainly only a parts motor as it’s apparently been submerged and then let sit. It’s a 1985.
      Appears to me that it’s impossible to remove the carb without removing/dismantling the starter, because the starboard carb nut isn’t otherwise accessible. Am I missing something? Is there a way? In my (limited) experience those pinion starters are best left alone if possible.
      am
      #41729
        Nowhere near as bad as you are imagining. Remove the two screws from the top of the starter and pick it up just enough to pull it out of the lower bearing, then lay it aside to your right. Now go ahead and remove your carburetor. Don’t worry, it isn’t going to go sproinggg.
        #41734
        Rich Cerankowski
          In the past I have taken a old screwdriver put it on the edge of the nut and give it a tap in most cases this will loosen up the nut so you can remove it. good luck Big Rich
          #41736
          fisherman6
            That was discussed on this board back in June. Here is the link to the topic.
            viewtopic.php?f=2&t=7262&hilit=How+the+hell%3F%3F
            -Ben
            OldJohnnyRude on YouTube
            #41749
            amuller
              Thanks for the info, especially the thread with pics! This being a parts motor, I removed then handle, released the torsion spring tension, and took the starter and the cam follower thingy off. No problem after that except the ugliness in the float bowl. I’m beginning to think this motor may have been fed a load of water via the fuel tank.
              More generally: With things opened up there was no difficulty in unsticking the motor–some spray lube and gentle tapping on the piston heads did it. The Cylinder walls look OK, though I’m sure the rings are stuck. It it was a plain bearing motor I’d think it might be run. But it seems there is very little chance the needle bearings and their races aren’t rusted, such that running would result in self-destruction. Anybody disagree, and think a full disassembly worthwhile?
              #41753
              RICHARD A. WHITE
                quote Fisherman6:
                -Ben
                Yeah that was me, Frank’s advice is spot on worked well, I also tried the screwdriver tap method and that worked too, so both are good advice.
                classicomctools@gmail.com
