Home Forum Ask A Member OMC Big Twin Parts Purchase
  • #200984
      Will be needing to order parts for the 1957 Evinrude Big Twin 35 hp,
      and am wondering if carb kits and ignition tune-up kits, and lower
      unit seal kits are available for these?
      Looked a little on the Net, and find individual parts here and there.
      I have no numbers for “kits”, so that doesn’t help.
      Suggestions for finding kits, or your favorite, reasonable priced place
      to shop for OMC parts?
      Thanks.
        Buc – I believe your motor will use the same kits as my ’56 30hp. I usually buy my parts on Marinengine but for whatever reason, I found better prices for most of these kits on Ebay. Of all places, at the time I was shopping for it, I got the best price on the carb kit on Amazon.
        Carb kit – 439074
        Tuneup kit – 172522
        Water pump kit – 379774 (includes pump housing)
        Gearcase seal kit – Sierra 18-2686
        If you don’t have it, here’s a link to a listing of kits on Marineengine. Even this listing is not totally complete.
        http://www.marineengine.com/parts/brp/
        #201000
          Thanks Bob, very helpful. If I ever had the “kit list” bookmarked,
          it was long forgotten.
          Now if I can make rhyme or reason out of it. Seems they’re shy
          about listing my 1957 model. For instance, with the kits below,
          it looks like they’re two choices for points and condenser in the era,
          but yet they don’t show 1957. Any reason? I don’t know what
          the difference in the kits may be either.
          Ignition tune-up kits, points & condensers
          25 1955 172522
          25 1969-1976 172523
          28 1962-1964 172523
          30 1956 172522
          33 1965-1970 172523
          35 1958-1959 172522
          ME does list the point sets separate for mine though….
          35 1957-1969 580148
          The closest I see on the carb kit is for a 1959 model.
          35 1959 439074
            Buc – in looking at the tables I also saw it seemed shy on listing the 57 model which is why I noted it seemed incomplete. No idea why the 57 model is omitted on certain kit listings..
            The individual tables for points and condensers both list the same numbers for both 56 and 57 30/35hp motors so the 172522 combo kit is correct for both.
            Not sure how I figured out the 439074 carb kit for my 56 motor but stands to reason if it worked on my 56 and the table lists it for a 59 motor it will also work on your 57.
            #201013
              172522 tune-up kit contains 580148 points (2) and 580321 condensers (2)
              172523 tune-up kit contains 580148 points (2) and 581419 condensers (2)
              172525 tune-up kit contains 580290 points (2) and 580256 condensers (2) (for V4)
              CORRECTION: Only one condenser in the V4 kit.
              • This reply was modified 5 years, 10 months ago by frankr.
              #201032
                Thanks for the info Bill and Frank. Would the 580321 and 581419 condensers
                be different mfd. ratings, or what? I’m guessing they both mount the same.
                The prices on ME are the same for either.
                Bob, did you find any lower unit seal kits, or source all parts individually?
                Thanks.
                  581419 is a tad longer and higher mfd.
                  #201042
                    Buc – gearcase seal kit is Sierra 18-2686 or GLM 87607.
                    #201046
                      Thanks again guys. Looks like I need to make some permanent notes……
                      great information to have handy!
                      rmhxruss
                        This carb kit and water pump kit went obsolete in 2017.
