Home › Forum › Ask A Member › OMC BUSHING 303140
- This topic has 9 replies, 6 voices, and was last updated 9 years, 1 month ago by
Buccaneer.
January 30, 2017 at 2:47 pm #6227January 30, 2017 at 3:39 pm #52130
I’d probably use a piece of Delrin if I were going to make one. But the old one usually can be re-used.
January 30, 2017 at 4:25 pm #52133Yes, I’ve made them out of Delrin (Acetal) before as thy are stupidly overpriced and have to be ordered in by my dealer. One thing I learned is to bell or taper the top well at the top of the bore. If you don’t and turn it square, the gear wont fit properly and you’ll have to start over again. That gears shaft might be odd sized on these or it may have been worn but I seem to recall using a small boring bar to size the bore after drilling. Too large a hole and the gear will wobble around. Sharp tools with a small radius are a necessity.
January 30, 2017 at 11:32 pm #52165Mumbles, if I remember correctly, the bushing wall is only about .035.
I wasn’t sure if a person could machine one on a lathe or not.
Guess anything is possible!
I looked at the bushing again today. Most of it’s wobble is the bushing
rocking in it’s bore, rather than the gear stud loose in the bushing.
I may just try epoxying the bushing in it bore and call it good…..
then again, making a bushing sounds like a fun challenge!
Thanks.Prepare to be boarded!
January 30, 2017 at 11:46 pm #52166BuRP is just trying to get all the old motors junked. The original vendor may still be around. Any old OMC people around to shed some light.
January 31, 2017 at 10:49 am #52200Buccaneer, If you’re not able to make one I just bought a NOS off eBay for 7.95 including shipping. There’s a few left.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi … 1537215908January 31, 2017 at 4:16 pm #52208Steve, thanks for the head’s up, I didn’t see that one
on my searches.Prepare to be boarded!
January 31, 2017 at 4:32 pm #52209Yup lathe will make them nicely…. Just need the stock and time…..But how many are really in need? Are they the same size or ALL the motors? Those are the questions…..I have the turret for my lathe, so with that, these could be made quite efficiently. As if I don’t have enough projects…LOL
classicomctools@gmail.comJanuary 31, 2017 at 6:20 pm #52214quote Buccaneer:Mumbles, if I remember correctly, the bushing wall is only about .035.
Thanks.Acetal turns really nice so with multiple light passes, getting the wall down to 0.035 should be no problem. If the bore for the bushing is worn, it could be drilled out and a thicker wall bushing made to fit but using some epoxy to hold it in place is quicker and easier.
Corrosion likes to build up on the outside of the bushing squeezing it tight on the gears shaft. It can build up on the shaft to but a good cleaning of the shaft and bore with a Dremel followed with some Triple Guard grease makes for easy throttle twisting.
January 31, 2017 at 10:28 pm #52220Mumbles, Think I’ll order some acetal stock tonight.
Sounds like handy stuff to have around, and maybe
more practical than brass in some cases.Prepare to be boarded!
