Home Forum Ask A Member OMC fuel connector 375587
  • #259179
    russ
      Is it possible to fix a nipple on this fuel connector.One of the them is broke off at what looks like a small coupler part way down on the nipple.Silver solder? Or can this be removed from its housing? Russ….
      #259185
        Is that the tank end?
        #259186
          Can we assume it isn’t one of the ones with threaded nipples?  If not, you might explore the possibility of drilling out the piece and thread the hole for one of the older threaded nipples.
          #259188
          russ
            No this one does not have the nut on it.Just my Luck.Thanks will have to see what I can do with it…….
            #259224
              A few years back I posted some photos here about repairing one of these broken dual line connectors.  Dang if I can find them in my library and I suspect they are probably being held hostage by Photobucket.
              Keep the faith and I’ll keep searching.
